import os import sys import time sys.path.append(os.path.join(os.path.dirname(__file__), '../../..')) from xarm.wrapper import XArmAPI arm = XArmAPI('192.168.1.135') arm.motion_enable(enable=True) arm.set_mode(0) arm.set_state(state=0) arm.set_tcp_jerk(10000) arm.set_joint_jerk(500,is_radian=True) arm.save_conf () arm.reset(wait=True) speed1 = 1000 mvacc1=50000 arm.set_pause_time(1) while True: arm.set_position(x=400, y=-100, z=250, roll=180, pitch=0, yaw=0, radius=50, speed=speed1, mvacc=mvacc1, wait=True) print(arm.get_position(), arm.get_position(is_radian=True)) arm.set_position(x=400, y=100, z=250, roll=180, pitch=0, yaw=0, radius=50, speed=speed1, mvacc=mvacc1, wait=True) print(arm.get_position(), arm.get_position(is_radian=True)) arm.set_position(x=300, y=0, z=250, roll=-180, pitch=0, yaw=0, radius=50, speed=speed1, mvacc=mvacc1, wait=True) print(arm.get_position(), arm.get_position(is_radian=True))
